And somebody here knows HOW I CAN TAKE THE GOLD BAR and the trashes and barrels?? I never can do this. please, help me ok?? Thanks again and again. hehehe
And about FINAL FIGHT
- INNUENDO
- MARPaltunnel Wrists
Hey, I think you can answer Barry. What´s the Gamest score on this game??
- destructor
After long time again GOLD BARS and DIAMONDS
First I copy all old info.
Today insted Haggar I used Cody for this trick.
Where is key? Key is in timing between press punch and press next button OR between destroy object (trash, barrel) and press next button. I'm more sure that time is counted from hitting object than from press punch - A.
Next button can be JUMP button or any joystick DIRECTION.
You can hold A and next button, it's never mind if you release it but better still press button B (see example below).
Otherwise hardest is TIME, we must do point 3 in right time.
I think you can press B more than one time and key is if you hit B in right TIME. Example (right time is 0,3sec):
Player P21 for this trick first press A for destroy object and next press B and next UP direction.
http://marp.retrogames.com/r/ffightj
Two buttons (I count direction as button) are not required after press A. One button is enough. But what is easiest in P21 method:
or
Pressing two or more buttons one after one is more close to autofire than pressing fast one button only.
It is why when you fast circle joystick trick looks easier. Example:
GHEMANT wrote:alchemy technique in final fight:
destroy all barrells/cabinets with any attack, then in 1/10 Sec. press Up lever and fire button simultaneous
destructor wrote:I training more Final Fight and...
My technique to get diamonds and gold bars:
A = button1
Up = cursor/joy up
1. hit barrel (or something) with A.
2. press UP
You can hold or not button A or UP, this have no difference but easiest is:
press A and hold -> press UP and hold too.
But this is very hard to get diamonds or g.b..
If I use this technique A+RIGHT+UP then I get diamonds or g.b. too. I think important is time between pressing A and UP ... but maybe something other. But this is impossible to still pressing A and UP in good time, we are people, not terminators.
Here must be some trick to easy get diamonds or g.b.
-------------------Patwos wrote:"I have come to the conclusion regarding the law of alchemy that, as long as some sort of response is made (button is OK) the moment the object(?) breaks, it is OK.
What I mean is that, by knowing the timing of destruction, and by using the lever or the button, we can almost always score. The reason why Cody is hard to score appears to be because he has a much shorter alchemy response time (which is the duration of a split second) than other characters. In Cody’s case, the timing of alchemy is right after (almost the same moment) the punch. Compared to that, Guy is faster, and Hagger is slower. ( talking about the punch.)
The numbers of Diamonds and the objects which can turn into gold, from the first screen, are 11,14,9,6,38,49 (total of 127). Among those, 1,1,2,2,6,6 (total of 18) definitely have the stuff in them. That means it is possible to score as many as 1,090,000 points just from the alchemy."
1. Press A
2. TIME
3. Press B or move joystick.Otherwise hardest is TIME, we must do point 3 in right time.
A - hit object
B (0,1sec after A)
B (0,2)
B (0,3) - hit
B (0,4)http://marp.retrogames.com/r/ffightj
A
B - too fast
UP - hit
A
B - hit
UP - too lateIt is why when you fast circle joystick trick looks easier. Example:
A
UP
RIGHT
DOWN - hit
LEFT
UP- destructor
I test it with different buttons (directions) after press punch and all works the same, except punch. You say that after press punch I should press punch again. Sorry but with punch I never get diamonds or goldbars.GHEMANT wrote:however, official and correct technique is:
HAGGAR and GUY: press punch (destroy item) then, in 0,033 sec. press punch
CODY: press punch (destroy item) then, in 0,033 sec. press LEVER UP +punch.
- destructor
Do you see hands of player on this video? Today I tried 1mln times using punch only and success. If I use B/direction I made items very often. I think something wrong is with this your video. Maybe player have special electronics under A button.
Can you cut a small part this video (for fast download) and show for me?
EDIT
Method A - B - UP works very well. With Haggar is a bit harder to learn but after learn timing my 80% hits was diamonds and goldbars. UP must be immediately after B. After UP can be DOWN too, it's fast move joystick in another direction.
Still no luck using A button.
EDIT
- destructor
eh ehdestructor wrote:I tried with autofire on A button too, no success, 1mln tries. With autofire on B button all works fine.
default autofire on mame is not good because it's very slow
for use autofire on A button, you must use autofire with 30 shoot/s with stick.
difficult question for me. I know that many command bridge are modify with extra buttons, I suppose for final fight there are 3 buttons:Chad wrote:do they install these autofire buttons into the machine, or do the players use devices to hit buton real fast?
button 1 = attack
button 2 = jump
button 3 (extra button not default) = attack autofire
- destructor
Heh. I don't know if diamonds and GB are possible with button A but for sure are possible (EASY to do) with button B or with directionsGHEMANT wrote:eh ehdestructor wrote:I tried with autofire on A button too, no success, 1mln tries. With autofire on B button all works fine.is normal if you use autofire on mame emulator.
If someone will made D or GB using A button only or have replay with it (replay for watch by me
EDIT
I check more using pause (P) and step by frame (shift + P) and P21 replay (he deleted it from MARP because he has A and B button under one key).
And now I have more correct info
HAGGAR TIME
TIME is counted from press A, not from hit object! TIME between press A and button B/direction MUST be 11 frames.
Example.
frame 0 - A
frame 1 - A (because you are not Terminator and A is still pressed, you can hold A even until frame 11 it's never mind)
frame 2 - A
frame 3 - A
frame 4 - nothing
frame 5 - nothing
frame 6 - nothing
frame 7 - nothing
frame 8 - nothing
frame 9 - nothing
frame 10 - UP
frame 11 - B (and still UP is pressed)
Example with miss frame 11:
frame 0 - A
frame 1 - A (because you are not Terminator and A is still pressed)
frame 2 - A
frame 3 - A
frame 4 - nothing
frame 5 - nothing
frame 6 - nothing
frame 7 - nothing
frame 8 - nothing
frame 9 - nothing
frame 10 - B
frame 11 - B
frame 12 - UP
Game have 60 frames per second then 11 frames is:
11/60 = 0,183 sec
Now, when I know what time in frames is required I can check theory with A button, GHEMANT
EDIT
Sorry GHEMANT but when I hit A in frame 11 no diamond or GB. I still have on HD replay for CANAME where player have autofire for button A but he don't use A button to made diamonds or GB, he press A button once and next he circle joy and hold button B - under B button he have autofire too. Then button A for sure doesn't works.
How easy test it?
1. Stay with HAGGAR near object
2. Press P (pause, I use wolf106),
3. Press A (and hold until next point because if you release it during pause, no signal will send to MAME)
4. Press SHIFT+P (step by one frame) - A button is visible in this frame by MAME
5. Now you can release A
6. Press SHIFT+P 10 times. Next frame will be 11 from hit A!!!
7. Press B or joystick to any direction and HOLD until point 8 because will be no signal if you release it during pause
8. Press SHIFT+P, you can release B (or joystick direction now).
9. Press P - you will see diamond or GB now
Time to check GUY and CODY times now.
GUY - 5 frames.
5/60 = 0,083 sec
CODY - 5 frames too.
How work autofire in wolf106 on button A for example.
Delay = 1
frame 0 - A
frame 1 - nothing
frame 2 - ACode: Select all
frame 0 - A
frame 1 - A
frame 2 - nothing
frame 3 - A
frame 4 - A
frame 5 - nothingCode: Select all
frame 0 - A
frame 1 - A
frame 2 - nothing
frame 3 - nothing
frame 4 - A
frame 5 - A
frame 6 - nothing
frame 7 - nothing
GHEMANT wrote:I see a old video and JUMP is not used
I see punch (to destroy object) and gold bar appear. Not other movements are visible (like left or right direction, or jump or down).
I thought about it today, and I knowGHEMANT wrote: player have autofire on button A. In Final fight 90% of players use autofire in Japan, and this video is one of this.
- destructor
Summary.
Method for get Diamonds and Gold Bars from objects (barrels, chests ...) depend from TIME between hit A and next hit button B or joystick direction (button A can't be used for it!). TIME is different for characters.
TIMES:
GUY
5 frames = 0.083 sec
CODY
HAGGAR
11 frames = 0.183 sec
For example: how is counted 5th frame for GUY:
After hit button A you can hold this button, you don't must release button A. During frames 1 to 4 you can do what you want, hit buttons or move joystick. Most important is frame 5 when you must hit something different than button A and different than key from previous frame.
Example:
Good luck in training your timing
Thanks to P21@Team2ch.jp for clear and beautifull replay where I analyse Haggar time!
Thanks to MAME Team for MAME, and thanks to person who add frame by frame run game in MAME emulator.
I search correct info about this trick from 20 july 2004, today is 9 september 2007. Finally I found it!
PS. My info is different than japanese? Hmm... probably I'm better cheater
TIMES:
GUY
CODY
HAGGAR
hit A
frame 1
frame 2
frame 3
frame 4
we are in frame 5 now! - hit B or move joystick to any directionExample:
hit A
frame 1 - Up, A
frame 2 - Up, A
frame 3 - Down, A
frame 4 - Down
we are in frame 5 now! - hit B or move joystick to any direction but Down direction will not work now because Down was in previous frame!Thanks to P21@Team2ch.jp for clear and beautifull replay where I analyse Haggar time!
[/img]
