my playback file for 'centiped' (centipede) is corrupt..
i've tried to re-upload it,
but the board won't let me..
how do i correct this?
i've tried renaming the input zip
filename, but that didn't work either..
skito asked me to re-upload it,
by the way..
later
ne ga ti ve 1
how do i re-upload a file?
i've never tried this but i've heard it works, you know the place that asks you to browse for the file.zip on your computer when you upload? instead of putting a local file there, past in the URL of the file you've posted it at on another site other than marp. and see if that works.
if you are just having trouble reuploading a new zip for the same score, edit the previous score to a lower value or move the game name to deleted to deleted it, then you should be able to reup it.
_reupload_
ok, i tried lowering my score..
that didnt work...it still said the file
previously existing..
and the ftp upload has never worked for me,
i get:
There has been an error processing this script. If you believe this is in error, please mail admin@ztnet.com with the url and any other related information.
later
ne g ativ e 1
i get:
later
ne g ativ e 1
_deleted_
ok,
i was able to delete my old file..
but now i still cant upload..
(either locally)
or using the full URL..
[same error as above]
it won't let me upload, i get:
./inp/rg1_centiped_362363_win61.zip already exists; did you upload it already?
correct the bad stuff and resubmit, or whinge to Zwaxy
later
ne ga tiv e 1
(either locally)
later
ne ga tiv e 1
ok
i finally got it reuploaded..
the file name has a score of 1 point higher,
but the internal file is right..
thanks again for all the help
later
n e g at i v e 1
later
n e g at i v e 1
